create a bible application
1 replies · 3,684 views · Started 20 December 2005
Can someone teach me how to create an application that can read,write and search into a txt files?Also create a menu item.Thanks...
Might be easier to locate existing (already available) bible reading/searching apps (I'm sure there are several to choose from).
If you want to do it yourself, the tools and documentation you can find on http://forum.nokia.com/java for Nokia's Java based phones. Note that for file system access you need a phone that supports JSR-75/FileConnection API.
You might also search the net for books about J2ME (Java 2 Micro Edition) programming. E.g., these:
http://forum.nokia.com/main/1,6566,40_27,00.html
http://www.symbian.com/books/j2me/j2me_info.html
