Are there any other N70 compatible wired headsets?
5 replies · 2,474 views · Started 20 December 2005
I just got an N70 for the missus but she has got small ear holes and I am not sure that the ones supplied with the N70 will fit! Are there any other wired headsets available that work with the N70 or any suggestions as to which provides the best stereo and voice calling capability? Or can you get an N70 to 3.5mm stereo jack convertor?
Groovy man, should of thunk of that really.
Are those just the old pop port headsets? I think I have some of those knocking about in a draw somewhere if they are.
Shame Nokia didn't think to make their adapter to a 3.5mm stereo output with a mic input as well - has anyone ever seen a compatible adapter that does that? I know you can get them for phones with a 2.5mm headphone socket.
I had this problem, and I got the ad-15 adapter from ebay (you can get it from mobile sites, but I am a cheapskate!)
It basically enables you to use your own headphones, and stops the problem with you head phones falling out!
And it sounds better. only gripe is, there's no microphone, so you can't use as a handsfree.
One way would be to modify the Nokia headset and put your own speakers on them, This does have the potential to damage your phone though as you would need to find some headphones that are the same impedance as the Nokia one's,
It's not recomended you try this unless you know what you are doing!
Carl,
Done this before, but the wires inside the headphone cable is sooooo thin that soldering them up is a nightmare. At least to someone with bananas for fingers like me!
