Someone knows about softwares allowing to see the symbian 80 and later versions based phone's display on your computer's monitor as the Remote S60 does with the Symbian 60 based one's or the Remote Display allows with WM or Smartphones ?
Browsing around in the net i was able only to find Remote S60 suitable to be used only with few phones.
Thank you
Roberto
roberto77 wrote:Someone knows about softwares allowing to see the symbian 80 and later versions based phone's display on your computer's monitor as the Remote S60 does with the Symbian 60 based one's or the Remote Display allows with WM or Smartphones ?
Browsing around in the net i was able only to find Remote S60 suitable to be used only with few phones.Thank you
Roberto
try Digia_ImageExpo_3.1.17.
i forgot the url... just search it.. 😊
Thank you for the suggestion 😊
There is also Remote80. which is Exactly like remote 60 for the series 80 phones.
Thank you all for suggestions, i tried "Image Expo" and it worked fine, althougs it is limited to few phones, for istance i was unable to run it with Nokia N70.
