Upgrade of RS60 for N9300 or N9500
2 replies · 1,866 views · Started 21 December 2005
Someone knows about existing softwares who allows to wacth 9300 or 9500 display on the computer's monitor ? as RS60 does with Symbian 60 based phones ?
I'm unable to employ RS60 with 9300 or 9500 because running later versions e.g S80
I browsed around in the net looking for such a sotware but finding only RS60
Thank's
Roberto
I don't know what 'RS60' does, or what exactly you're looking for, but Remote S80 will let you see the Communicator's screen and control the device from a computer...
Roberto ....
I don't know if you are satisfied with Remote S80 software sent by Raven.
But I have a software that allows to wacth 9500 and 9300 display ( All S80 )on the computer's monitor , without any control from PC ,the control will be just from mobile ,
and it's free .
If you wont it just tell me.
thanks
Muhannad
