Ringtones for 9290
4 replies · 1,690 views · Started 18 November 2002
You mean compose a ringing tones? if yes try "Ring Master". :fadein:
Yes this was the only one I know either from 9210. or else you can try others PC's applications. 😉
you can use MP3 songs, convert it to .WAV file using Multimedia Convertor.. and use it as a ringtone.. 😉
and if you are looking for .RNG tones.. as guest said, RnngMaster, you can compose tones, and edit wav files
http://www.allaboutsymbian.com/software/directory/viewsoft.php?id=175
Regards 8)
