How do i VIEW downloaded themes?
1 replies · 2,446 views · Started 21 December 2005
I've downloaded a couple of .SIS files wich contain themes.
To prevent a lot of clutter on my phone i want to view the theme's before i go on and install them.
However, every search i type, it all ends with: Nokia Theme Studio.
Well, it will offcourse be my clumsyness or something, but i find no way to open / view a .sis document with Nokia Theme Studio 2.0 (Nokia N90)
When i open the program, and go with the browser to the map where all my sis files are, nothing appears in the browser (even when i extend it using the button on the top right of the browser window)
According to the manual (help) in Nokia Theme Studio it should be possible to open / view .sis files ... but how do i do that!?
When i try to open such file, it says "selected file is not a valid theme package"
So obviously i seem to do something wrong, but i can't see what.
Anyone has any suggestion?
Thanks in advance
[edit]
from another post while using the search function:
And to view them,you need to put the .sis file in Program files/theme studio/data/skins dir folder, then click on sis files in theme studio to view it,
There will be no edit option tho as N/A has said
Also tried this, and it doesn't fix it. I still don't see the theme (while i'm sure there's a theme in the .sis file)
Theme studio v2.0 will only open .tdf files,and not .sis files,which is strange because v1.2 used to.
