Headset problem
4 replies · 1,801 views · Started 24 December 2005
Hi all,
i have dropped my headset many time , now its not working properly, can any one suggest some other headset which is supported by sendo x .This will be of great help to me , please help me
i think its important that the plug is a 2.5 mm thing.. hope this helps..
best regards asalvus
The moto mpx200 headset should work with the X. I know it's 2.5mm jack, but I'm not sure about the connection pins though. But there is good feedback on this type. I had a lot of probs with the standard headset Sendo provided. It's crap imo. Here in NL there are some stores which sell the moto ones: http://www.complaza.nl/inquire.php3?prodid=10844
Otherwise you could check eBay. Good luck😊
Edit: Ok, maybe a Dutch shop isn't that convenient...😉 Maybe this guy: http://cgi.ebay.com/OEM-Motorola-Headset-MPX200-T730C-T731-P8160-AAYN4264_W0QQitemZ5844443427QQcategoryZ20354QQrdZ1QQcmdZViewItem
Hi guys
Thanks for the replies , so can i get mpx200 headset , will it work , can some one confirm me about it
thanks in advance
