Please tell how to download player for dat for Ngage qd
Media Player/ dat player for Ngage Qd
Which "dat" do you mean? Often developers just use a .dat file extension to refer to various kinds of data files, but the content format could be anything they choose to use.
Did you have some specific "dat" file format in mind? If so, what? DAT as in Digital Audio Tape as defined by Sony (the only audio related format I can recall)? Something else?
😮 ...for phone, there aint player for dat.file
if ya got smartplayer then u can convert dat.file to avi or
using xsiliconvert to convert it to rm,avi,xvid,3gp....
Deepakc wrote:Please tell how to download player for dat for Ngage qd
:hello: my name is saurabh. i m interested in downloading some software to play video efficiently with some advanced features, thats y i want to download media player. i also wanted to download smart movie player & having same problem that is dont know how to download it :dontknow: !!!
so could u help me for the same? i will be gr8ful if u can.
thanking u.
saurabh kapadia.
U can d/l it by PC (Internet Explorer): http://www.lonelycatgames.com. I think u can't d/l it from ur phone because they don't support for WAP.
dear rulirahm,
got ur advise. actully i had tried to download smart movie player
from lonelycatgames.com but it provides only trial version & not full version which i m searching 4. do u have any idea about that?
regards,
saurabh.
There is a freeware converter, running under windows. The format it will be .3gp (for video). It called Nokia Multimedia Converter 😊 . U've to join Nokia's forum:
http://forum.nokia.com to get the free registration code. Here, I found the site:http://www.forum.nokia.com/main/0,,034-63,00.html.Hope this helps 😉
