Please Help �Build failure Problem
2 replies · 1,410 views · Started 27 December 2005
:icon2: Please Help �Build failure Problem
I am using Borland c++BuilerX 1.5 for developing a series 60 application using Symbian C++. For the emulator I was using Series 60 Sdk 2.0 For Symbian Os Supporting Borland C++Builder and UIQ. It was working very well. After a certain period I face problem on the Compilation and Build. I reinstall everything and tried as I did and succeed previously; but same problem still exists. Now I can�t proceed on the development. The following are the Build error messages shown in the box.
Compile Errors
bldmake -v bldfiles
� 'perl' is not recognized as an internal or external command,
abld -v export
� 'abld' is not recognized as an internal or external command,
� External process exited with error code : 1
abld -v makefile WINSB
abld -v resource WINSB UDEB
abld -v library WINSB
Build
abld -v target WINSB UDEB
abld -v final WINSB UDEB
abld -c build WINSB UDEB
abld -w build WINSB UDEB
How can I get it solved? Please Help me.
Thank You in advance.
Shiferaw A.
Sounds like Perl is no longer installed, or no longer on the PATH (what does the command "perl -v" display if you execute it from the command prompt?).
If it isn't installed, you can download and reinstall it from http://www.activestate.com/
Pls Hlp me on Build failure
Thank you; I get Active Perl installed and the problem solved now. Now the Compile and Build problems message looks like the following. It is related to 'abld". To be frank, I don't even know about 'abld' and how to get it corrected as I am a starter with Symbian C++. How can I check for correcting environment variables for it? Or How can I get it solved?
The Failure Message follows:
bldmake -v bldfiles
abld -v export
�External process exited with error code : 1
Compile finished
Build finished
Please help me.
Thanking you,
Shiferaw.
