Themes don't work on 6630
0 replies · 1,443 views · Started 29 December 2005
Hi.
I have a Nokia 6630. I upgraded the firmware to V 5.03.08. At the beginning everything worked properly and I installed some themes. Then I tried Nokia Theme Studio 2.0 to create a theme. It didn't work, I searched the internet and I found out that version 2.0 is only suitable for N70, N90 and some others. So I downloaded version 1.2.1 and created another theme. This time the error message was "Unable to install. Compatible with Series60SkinsSupport version 0.00". Searching the internet I found out that someone who had this problem solved it by uninstalling all the themes. I did it and this didn't solve the problem, but now in addition I can't reinstall the old themes! I reset the phone (twice, both with *#7730# and with *, 3 and the green key on startup), but the problem is still there! Now only Nokia theme works! The other preinstalled theme (TIM, operator) appears in the list, but if I select it the phone doesn't say "Theme applied" and changes the icons only. On the other hand preview for that theme works. What should I do? What can have happened which has not been fixed by the reset?
Thank you and excuse me for my bad english.
