i wnated to know if there is an app that functions well with 6600 regarding videotones... also wanna know how do i insert emoticons in a message??? is there a app which supports emoticons.. plzzz hlp
videotones 4 6600
Try Psiloc Vision (you can find it in the shop: http://www.allaboutsymbian.com/shop/).
No emoticons support in the Messaging app (but you can type them as the text characters and if the receiver has a phone that can replace them with emoticons, it will work for them).
N/A wrote:Try Psiloc Vision (you can find it in the shop: http://www.allaboutsymbian.com/shop/).No emoticons support in the Messaging app (but you can type them as the text characters and if the receiver has a phone that can replace them with emoticons, it will work for them).
hellllllllllllllo
helooooooooooooooooooo sir who r uuuuuuuuuuuuuuuuu:icon2:
Tankssssssssssssssss
