[CENTER]:con? :con? :con? :con? :con? :con? [/CENTER]
I did a search and it seems like I'm the only one with this problem.
I've contacted T-mobile and they've been no help at all. Still get the same error message whenever I try to connect, i.e.
Packet data: Packet data not available. Please check network services
What should I do?
Please help.
First verify with T-Mobile customer service thay your plan/subscription has (allows) for packet data (GPRS). When you call, tell them your phone number & name & ask them to check that packet data/GPRS access is all right from their point of view.
Then have T-Mobile customer service send you a configuration message with the correct settings, or try the "Settings Wizard" for the N70 (http://www.europe.nokia.com/nokia/0,,76742,00.html?model=N70), or order them from Nokia's web site: http://www.europe.nokia.com/nokia/0,,71993,00.html
