Help with FSCaller
5 replies · 1,806 views · Started 03 January 2006
Hi
Installed FSCaller (Trial) when I first got my N70. But deleted it after few days cos' it 'disables' the 'Go To'.
Now realised that beside this, it works fine with N70. Sadly, the trial period is over and I can't try it out further before buying it.
Need help from you guys who has FSCaller on your N70 (esp!!) or other model to confirm a few things:
1) When a call came in, the photo displayed. There's an 'Options' (left soft key) and 'Silence' (right soft key) displayed. Does the 'Options' contains activation for the 'Loudspeaker'? What other features are there under the 'Options'?
2) Beside disabling 'Go To', any N70 users face problem with this application?
1: no first u have to answer the call then the right soft key becomes loundspeaker
2: if you use fexplorer & go to c:\system\favorites & delete the link called fscaller then you will revive your 'go to'
thats the only function that doesnt work so far that i have found usding n70
thanks steff2632.. forgot to add.. when you make an outgoing call, would you be able to activate the loudspeaker before the other party answer the call (when you use FSC)? this is possible with N70 (if no Power Call installed) but with Power Call, i need to wait for the person to answer the call, then press the 'green' button to get out of Power Call and activate 'Loudspeaker'. find it inconvenient.
FSC has the same problem??
For the Go To problem, i manage to figure that out too. thanks for sharing. 😊
One more thing, saw one user (N7610) having problem with FSC and SMS Reminder - it will not auto start after you off and on the phone.
I have this problem with Symbianware SMSReminder. Do you have this problem with FSC on N70??
i dont have power call so cant tell you however the same in call options apply when using fscaller
& when i turn my phone off & back on fscaller autostarts check in the drive that you installed fscaller for this file (e:\system\sw_autoExec\fscallerd.aex or c:\system\sw_autoexec\fscallerd.aex)should auto start if this filer is there
interesting.. following your instruction, managed to find the file in the c:\system.. but i also found SMSRemdiner.aex file there... but it doesn't work?? wonder why.. still considering getting FSC.. cos' it's a bit troublesome if everytime i wanto use loudspeaker i have to go through the hassle..
