Problem With calling and getting codes
2 replies · 1,773 views · Started 03 January 2006
Hey all,
Well i just purchased the 7710 and i have a problem. Well I cant figure out the codes to call and stuff. How do i do this. My manual said that i should go ahead and call my service provider and they should give me it. some one please help!
What do you mean, exactly, with "the codes to call and stuff"? Which "codes" (for what purpose)? What "stuff"?
A service provider (network operator) can usually provide
- default PIN and PIN2 codes for the SIM card
- PUK and PUK2 codes for unblocking a SIM which PIN codes have been incorrectly entered too many times
- a (PIN) code for an answering service
- an unlocking code if the phone is SIM-locked (restricted) to only use that operator's SIM cards
For those codes, call your operator.
If it is something else you want, please explain.
PIN = Personal Indentification Number
PUK = Personal Unblocking Key
SIM = Subscriber Identity Module
N/A wrote:What do you mean, exactly, with "the codes to call and stuff"? Which "codes" (for what purpose)? What "stuff"?
Whenever I want to make calls it shows a lock sign then says Disconnected. I need the barring code for phone calls.
Thanks😉
