Hard Reset N70!
17 replies · 248,279 views · Started 03 January 2006
I tried to "HARD FoRMAT" my N70 with holding 3 keys; Green dial key, * Star key, no. 3 key on keypad bUt is not FoRmAtTiNg N70....
Any ideas ???
Any other WaY ???
No other way. Try again (it can be a bit tricky to get going). When it is done, you will recognize it by the phone asking for the home country/city again at startup.
Try this easy way dial *#7370# after that it will ask for security code dial 12345 it's by default!
Try the green/3/* thing again (until you get it to work).
- Turn off PIN code requests.
- Charge the phone fully.
- Turn off the phone.
- Remove the memory card (not really needed, but I usually do it to be on the safe side).
- Put the phone on a table (easier to press the keys then, in my opinion).
- Press the three keys and keep them securely down and do not release.
- While the keys are still down, turn the power on.
- Do not release the three keys until you see the prompt for the home city.
If it doesn't work, retry until you get it right. It is easier if you have three hands. 😉
N/A wrote:*#7370# will not reformat a N70, but just reset settings.
I thought that *#7780# just reset settings and that *#7370# did a soft format whereas [Green] + [3, def]+[*, +] does a hard format.
S.
If you perss those 3 keys or dail that number will it format everything so everything is gone or wil it be exaclty like it was when you bought it including all preinstlald progrs and videos? or what does it really do?
/Kim
The phone will, more or less, be back in the state it was in when it left the factory where it was made.
N/A wrote:Try the green/3/* thing again (until you get it to work).
hey.. just want to ask.. we tried for about 15 times and still "formatting" message doesn't show up.. what shall I do?
the hard reset still doesn't work for me.. I tried for about 15 times and still nothing happened. The mesage "formatting" still did not show up. what shall I do? Pls. help.. or better pls give your YM id.. thx... :con?
done hard format many thanks for this info! phone runs smoother now 😊
but that bar as come back on the home screen i did remove it once b4 but i just cannot find the right place to remove! im on orange and on home screen it has that stupid bar on side thats like a menu!! could some one please tell me how to remove it? thanks
dogie2x wrote:tThe mesage "formatting" still did not show up. what shall I do?
It won't show at all. Keep the keys pressed until the menu for selecting the city pops up.
i found it!!!! 😊
just go to nokia website download the updated software for ur n70 use data cable and update ur phone and the phone is much better without the stupid homescreen and best of all phone loads quicker
just formatting my 6600 with the 3key press.
it started by showing FORMATING in center of scr. then black line moved across screen to show how far it had done. It now loads up ok
jazzy1 wrote:Try this easy way dial *#7370# after that it will ask for security code dial 12345 it's by default!
hi,
i just try that one
but the security code or lock code is always CODE ERROR
can u help me with this problem??????:redface:
