the earpiece volume for 7650 is utter shit.
the same for all 7650's?
pls tell me if is worth to buy...
curious about ur opinions
thanks
Dan
p.s. dont say "search"in the forum,coz i didnt find answers to that
Reaaally Bad Earpiece Volume
Hello
My phone:the same problem.
Any solutions(software upgrade) or something?
I had'nt come across anyone with an Earpiece problem on 7650. Or did u mean the Handsfree speaker Volume? That ofcourse is a known issue.
I certainly did have this funny problem that, it infact, sounds low even if it moves a little. I mean, it needs rather precise positioning over the ear. But one gets used to it fast and is hardly noticeable. I have had 4 different handsets (7650) and they all sound fine. Vol setting of about midway to max is ok for even outdoors.
I droped my earpiece handsfree and also steped on it and one of the earpiece was destroyed. I had another handsfree (siemens sl45 very similar looks) and I changed the broken earpiece. Guess... It sounds louder than the other original earpiece. I think I will change and the other one.
It is so strange to know couple of users have problem with their earpiece. I don't have problem with mine. :P
no problems here either. 😃
dear friends,
i reported that 7650 does not have a pure voice as 8310 while you are using the earpiece. 7650 has a poor earpiece sound quality,but this phone is so effective and that worths to buy.
[quote="lazzeus"]dear friends,
i reported that 7650 does not have a pure voice as 8310 while you are using the earpiece. 7650 has a poor earpiece sound quality,but this phone is so effective and that worths to buy.[/quote]
of course. 😃
In my opinion, the 7650's earpiece volume was fantastic! I used the stero speakers from the 8310 and the quality was great. 😊
