GPRS setting for Orange UK?
3 replies · 5,119 views · Started 18 November 2002
Can anyone on Orange please post the GPRS setting please? I have two GRPS settings set up on the phone, one called Orange GPRS (which works fine for WAP) and one called Orange MMS.
Neither of these connections seem to work for programs other than WAP. (I expected the one called Orange GPRS to work). Should I create a new connection just for GPRS data (for use with progs like webviewer and TipicME)?
I'm guessing this lack of connection is the reason i cant use the GPRS for anything other than WAP.
Many thanks for any help you can give..
create a new access point and edit it with these settings.
Data Bearer - GPRS
Access Point Name - orangeinternet
User name - none (leave blank)
Prompt Password - No
Password - none (leave blank)
Authenication - Normal
Gateway I.P Address - 0.0.0.0
if you have probs browsing etc, when editing acount press options choose advanced settings and enter.
Primary name server - 193.35.131.194
Second. name server - 193.35.131.195
hope this helps. 😃
