Am I the only one who thinks the "Fashion headset" included with the N70 is pretty pants? The earphones are too big to fit in my somewhat cavernous ears. I'd like to use the old style HDS-3 headset & am poised to buy one but the N70 isn't listed as compatible. Can anyone tell me if it's possible to use an HDS-3 with an N70?
Headsets with N70
Yes you can use your HDS-3 headset with the N70.
If you go onto the Nokia website and look at the N70, if you look under Enhancements you can see all the different headsets that are compatible with the N70.
I tried 3 different kinds and all work fine
Why not just buy one of the "Music Adapters" on Ebay for about �3 including postage from Hong Kong, which converts the Nokia plug to a normal 3.5mm headphone jack socket, then you can use whatever headphones you like. I bought one a week or two ago and it works fine, although obviously only for music it doesnt have mic capabilities for handsfree phone use.
Chris
