Hi
The other nite I left my X downstairs overnight and came down to find it completely dead. I know the battery was low and Im assuming it just flatted out. Now it just wont fire up at all. Tried recharging and it initially came up with a bright white screen but when I checked it a little later it was dead and has remained so ever since despite being plugged in to the charger for over 24 hours 😡
Ive tried swapping a fully charged battery from my sons phone and still nothing. It has for a while been a bit finnicky charging - I thought this was the charger but I now know the charger is fine! Up until this it had worked fine - well relative fine, still had some infuriating bugs and would usually only connect 4 out 5 times.
Is there anything I can try or is the phone terminal?! :frown: Dont see how jusy flatting the battery could cause this shutdown tho!!!
Also - how can I check how up to date my firmware is (on the working X that is!)
cheers!
