i don't know if this has been discussed or posted but i was just fascinated from this that i have to show you!!
check this out:
http://www.dr-nokia1.pwp.blueyonder.co.uk/dismantle/7650_disassy/start.html
check this out:
Is that all there is inside the 7650?! Wow, the wonders of technology eh?
That narrator was just oozing personality! He should try a career change as a nightclub DJ!
I also love the way Nokia seems to have a product code for literally EVERYTHING, even the little plastic things is an SRT-6. Can you imagine what it must me like for the cleaners who have to refil the TCPD-1 (Toilet Cubicle Paper Dispenser) with DTP-2P (Dispensable Toilet paper - 2 ply)? You then have to wash your hands by activating the WPU-C and WPU-H (Water Provision Units Cold/Hot) which are attached to the PWC-1 (Pluggable Water Container). After applying the SCS (Skin Cleansing Substance), dry your hands using the paper provided by the TCPD-HE (Toilet Cubicle Paper Dispenser - Hand Edition).
[quote="TANKERx"]That narrator was just oozing personality! He should try a career change as a nightclub DJ!
I also love the way Nokia seems to have a product code for literally EVERYTHING, even the little plastic things is an SRT-6. Can you imagine what it must me like for the cleaners who have to refil the TCPD-1 (Toilet Cubicle Paper Dispenser) with DTP-2P (Dispensable Toilet paper - 2 ply)? You then have to wash your hands by activating the WPU-C and WPU-H (Water Provision Units Cold/Hot) which are attached to the PWC-1 (Pluggable Water Container). After applying the SCS (Skin Cleansing Substance), dry your hands using the paper provided by the TCPD-HE (Toilet Cubicle Paper Dispenser - Hand Edition).[/quote]
What ever you do !! Dont start taking your phone apart !!
remember kids !! dont try this at home 😉
I dont think Nokia will touch it with a barge poll if you take it back all selotaped together !!
be very careful when you separate the slide parts. there is a ribbon cable that when detacted from the board will ruin the handset.
Is tehere a way to just remove the front side ( or A-cover) to remove the dust inside?? In the movie it's done on the end but i don't want to take my whole phone apart
dust? i can sing a song about that! well u don't no other way than to bring your phone to your nearest service center! i had dust too and there's no way you'll bring it out!!
[quote="Shadow"]dust? i can sing a song about that! well u don't no other way than to bring your phone to your nearest service center! i had dust too and there's no way you'll bring it out!![/quote]
Why not?, I managed it :roll:
So how did u do it?
Is there a way to get the A-cover of the phone without taking it apart???
No there isn't, you have to split the phone, and dismantle from there, you obviously don't have to take the keypad apart! But I recommend talking the ribbon cable off the keypad as you'll probably break it if you don't.
If your not confident doing yourself, then I do reccomend talking it to an NSC, it's quite risky, I just did it because I couldn't be bothered to wait for NSC to do it.
yeah you're right! i mean after seeing the video! i knew that i have everything needed to deassemble the phone but i wouldn't do it cuz i want my phone to stay alive!! here in switzerland you can go to the store leave it there after 30 minutes you can get your phone fresh and clean!! and you still has a guarantee!!
hm okeee...
thnx for the reply 😊
