3230 Sob story=<..
2 replies · 1,979 views · Started 10 January 2006
I bot my 3230 May'05' and it stopped working as soon as i got of the plane. Finally a friend took it to Sweden and had Nokia fix it and now I have it back, but now it is locked and no longer can use just any sim. I purchased the unlocking software where you type in IMEI and get unlock code, but it didn't seem to work and I didn't want to try too much and cause it to totally stay locked. Does anyone know if this software works or does 3230 have to be done with it connected by wire directly to the computer? Heeeellllpppp. Thanx in advance.
Jeff
I was being a dork and was putting tmobile as the network in the software code generator, but I needed to put what the phone is currently locked to, not what I want it to work on. The problem is, I don't know what network it will work on in Sweden, so now I don't know what to put in the software to get it to generate the proper unlock code. My phone is a dct4. I hope I got that part right atleast, haha.
