hi guys and gals! im new here...
i'd just like to ask if the psiloc irRemote is accesible in my 3230 fone? I installed it many times to try that application still its not working...
i hope u guys can help me with my problem...
thanks in advance... :icon14:
This application is compatible only with:
Nokia 3650/3600
Nokia 3660/3620
Nokia 6260
Nokia 6600/6620
Nokia 7650
Siemens SX1
Panasonic X700
Samsung SGH-D710
One good reason for that app not working on your phone is because your phone does not have any infrared/IrDA hardware at all. 😉
LOL, Sure it does N/A!
CyberBlue: I've read about people getting particular versions of irRemote to work with the 3230. If you search you should find more information.
SeanCF wrote:LOL, Sure it does N/A!CyberBlue: I've read about people getting particular versions of irRemote to work with the 3230. If you search you should find more information.
poor me cant find it.. actually i dont know where to find it?:con?
Probably u have not downloaded the equipment (for which remote control is to function) "lirc" file. If you have, u have to import the functions in the lirc file i.e when u install lirc file, Irremote will automatically recognise it. Then u have to import all the fuctions. Once u have downloaded all the functions, the remote will work. Just point the Infrared point towards the equipment within 1m approx.
Can you please send it to me on [email][email protected][/email]
Here is a cracked version.
u can try it.
v1.72
rendu2mai wrote:Here is a cracked version.
u can try it.
v1.72
loads of thanks dude... i'l try it im gonna update you if it works or not... thanks!😉
