I have a N70, from Vodafone (Portugal), and I find some problems (newbie in Symbian OS) exploring and installing applications:
- I can't see the "System" from the disk or the memory card in the mobile explorer or windows explorer. In the mobile, if a perform a "find" it will find the System from the memory card but not from the mobile. How can i access this directory from the mobile and from the windows (Note: the explorer of the windows permits to see hidden and system folders and files);
- I try to intall the FExplore to access the hidden "system" folder. But the instalation don't execute because a error of "security reasons" (not the exact message because it is in portuguese, but the key words are this);
- I try to execute files with extension .app from a aplication that a laboratory where i work, but it doesn't execute with a similar message about "security reason";
In some threads the use of the FExplore resolve the problem of the hidden "System" folder. But a i can't install it and i still cant see it from the windows.
I also find something about enable "Advanced options" (?) and enable "hidden areas" (?). Is this correct? How can i enable it?
Can anyone help me with the problems above, please?I will been thankful.
Regards,
Marco
That is as designed. No good solutions.
menu > Tools > Manager > Options > Settings > Software installation > On (can't translate that to Portugese)
Execute on the phone? How? Properly installed .app files should appear as launchable programs in the phone menu.
Thank you for the information about the hidden folder "System". It is also impossible do see it from the explorer of the windows?
The problema for execute and install the aplications was a my error. Before read the above post i find in another thread the same information that forbid the instalation of aplications without certificated. This option of off for me.
The other problem executing the appliaction, aggain, my mistake, because I was trying to execute a .app file outside the System folder.
One more question: when I turn on the mobile there is a nokia animation with a sound. How can I disable it or at leats turn of the sound?
Regards,
Marco
the nokia animation & soundcan be disabled in the settings>phone>general>welcome note or logo
can chage it to what ever you like
the system folder if its on your memory card & you have the option in windows to see system & hidden folders & files then you should be able to see it using a memory card reader & the memory card
Thanks for your help.
Unfortunately I haved tryied this option, but in my N70 it only allows to insert a text or a image, the animation (and the annoying sound) still active. Other way to get around it?
Yes, i have that idea taken from other posts, but I do have the windows option to see system and hidden folders active, but i still can't see the "system" folder from the mobile memory, and memory card. Any other ideas?
Thank you again for your help.
Regards,
Marco
