mRouter Problem
1 replies · 3,807 views · Started 11 January 2006
Hello everyone. I have an n-gage qd. The problem that i am facing is that i cannot connect to the pc suite thru the mrouter though my pc says that my phone is connected(in 'My Bluetooth Devices'😉.whenever i try to select the port(in the mRouter) in concern it says 'IT IS NOT POSSIBLE TO ENABLE THE INFRARED PORT, AS IT MAY BE IN USE BY ANOTHERAPPLICATION'.:con? 😡
PLS HELP ME.
Whose Bluetooth hardware & which Bluetooth driver?
You're also speaking of Bluetooth and infrared at the same time. Which is it? The N-Gage has no infrared.
