what is the small thing
6 replies · 1,934 views · Started 12 January 2006
This thread included a poll: do you think i am helpfull
hi guys iv noticed the small squared lil light thing on the top left hand corner of the nokia n70 have ne of u guys got ne idea wot that is iv been trying to figuire that out but i couldent so will try to find it soon wot that is . reply me bak with the answers you got and wot that is and tell me how can it be used:con? :con? :con? :con? :con? :con? :con? :con? :con?
I believe its a light sensor for the screen, so if its bright sunlight it brightens the screen so you can still see it clearly, and visca versa when its dark
Chris
This is correct, it also activates the keypad lights in dark situations, try it, stand in bright light and put your thumb over the sensor, voila, keypad lights up.
VetDuarte wrote:Can it be shut down?
I'm looking for help on this too. As when driving at night with TomTom on the keypad lights are on all the time
the 7650 had one of these lso however it never worked! funny though there was a option to turn it on and off in the menus
