after installing a .sis file in my phone(N70) i can't open its menu.i press the menu button in my keypad but it only flashes the menu and returns back to standby mode. i wanted to delete the .sis files i installed but i couldnt open the menu. i tried turning my phone off, thinking it could solve the problem but still it can't access the menu. i need help..pls.. 😞
tnx...:s:
help pls..
Can you not get into the main Menus at all, ie cant get to Application Manager etc?
If you installed the app on the MMC card, you could try removing the card as this seems to effectively temporarily uninstall the apps from the phone whilst removed (the app icons disappear and the apps arent listed in App Manager). If this works then maybe wipe the MMC card in a PC card reader, then reformat it once you put it back in the phone?
