Checkout "hanging"...
4 replies · 1,916 views · Started 12 January 2006
So I have tried to read through as much as possible here, since I'm new...but instead of hijacking some elses thread I'll put it here.
I have completed my theme, no probs, the theme editor works with ease on my computer, but as soon as I go to checkout to finish and convert it to the .sis, the program just hangs and never completes....
Any suggestions?
TheBronx
Do you know where I coud download specifically that? I'm not sure if I'm using it...where can I find it?
When you install S60 Theme Studio, the 2.0 and 3.0 versions (at least), asked at installation time whether you want to use an existing Java (JRE, Java Run-time Environment) installation already on the PC, or install a private version for S60 Theme Studio.
My advise: Always choose to install a private version and use the version included with the program. That way you will get the right version; the version that was used to develop the program and - more or less - guaranteed to work.
