i have found this application here
http://www.spruce.jp/freemidlets/AlarmClock/
it consist of 2 files
AlarmClock.jad
AlarmClock.jar
i sent the
AlarmClock.jar
to my 7650
and it is installed ok but when i searched for it in thephone i can't find it
what does this mean anybody can help me if i have imstalled it wrong or do i need to send the other file
please help
Goto Tools then Apps your find all the Java programs in there !
Just click to Launch! 😉
Darkst0rm
Thanks alot
:angel:
but what is that files ?
AlarmClock.jad
and how to install it
jad file is java application description file, which tells the system the icon
and url and other things about the jar file. its not neccessarily needed
by 7650. you can open the jad file with notepad and look what it contains.
