SMSsync
1 replies · 9,546 views · Started 13 January 2006
hi, I'm using nokia N70. When i use pc suit same error appear on the secren and it say "please install SMSsync in your phone".
I dont have SMSsync , what is SMSsync and how can i find SMSsync.sis
I looked SMSsync on the web but i found nothink.
SMSsync gets installed with PC Suite and when you first try to use the messaging feature. So, the message (as I remember it when I did the installation) asks you whether you want to install it or not & then you should accept/finish the installation on the phone (like when installing any .sis file).
