Just wondering what memory cards are being used with working speed cameras ? and what cards are given you hassle?
Just noticed i had it working perfect with the single file ov2 and bmp files.
I only seem to get hassle with speed zoned versions that display the speed of the for-coming camera.
Who has Tomtom working with Speed camera POI's and what memory cards are being used
Hi
Well i just got my N70 and using Kingston 1GB memory.
Have TT Mobile 5.2 with speed cams http://www.pocketgpsworld.com/uksafetycameras.php
No problems here.
Take a look here for problems. http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=30302
Basically just disable all POI but have alerts on and select speed cams.
Cheers hope it help.
I am going to buy one of these 15Mb/Sec cards at �27 inc VAT and P&P...
I will let you all know how it performs...
http://www.techfever.co.uk/products.asp?partno=2983&source=affwin
PEAK 512MB RS-MMC MOBILE XTREME 100x
Flash Memory>>SD/MMC
Type : Mobile Multimedia Memory Card
Model number: 2983ADPK
Weight: 0.01Kg
Special Features :
The Peak MMCmobile 4.0 Card is Based on an Advanced 13-pin Interface with Dual Voltage and is Designed to Meet the Requirements of Different Portable Audio & Video Consumer Devices. It can Operate at Voltages of 2.7V - 3.6V as Standard. It can also Operate at Voltages of 1.65V - 1.95V Which Most Cellular Phones Require.
Specifications:
Package Type : Retail
Capacity : 512MB
Interface : MMCmobile
Read Speed : 15MB/s
Write Speed : 8MB/s
Operation Voltage : 2.7V to 3.6V, 1.65V to 1.95V
Insertions : 10,000
Width : 18mm
Height : 24mm
Depth : 1.4mm
Package Contents:
MMC Adapter
Warranty: 5 Years
