Problem connecting my Phone to PC.
1 replies · 1,118 views · Started 15 January 2006
I have a nokia 6680 and im trying to connect it to my PC.I am using the cable that came with the phone.When they tell me to connect my cable to the PC and my phone i plug it in and nothing happens.I thought it would just take a while so I left it over night.In the morning the screen was the same,my phone had not connected,I left it for a few more hours but still nothing.Does anyone know whats wrong.
Easier to help if you provide more info about your system(PC, what version) and it is important that you have installed the latest PC Suite version (6.70.22 from www.nokia.com/pcsuite)
If you have some anti-virus protection programs running, disconnect your PC from the web and close the anti-virus program, that might prevent the installing of drivers.
(if you have PC Suite installed, you can check your system easily with right click Pc Suite icon in windows tray (bottom right area), select "about pc suite" and then "system info".)
