"Documents to Go"
2 replies · 897 views · Started 16 January 2006
Have downloaded the trial of this app, seems to work really well for roundtripping. No format losses either way. Does anyone know how to insert bullets into a doc created in the app??
Went to the Data Viz website and answered my own question. For anyone else who is also battling, here is the bad news...
Question:
How do I create or delete bullet points and numbered lists on the handheld?
Answer:
Currently, bullet points and numbered lists cannot be created from scratch in a new Word file created on the handheld. However, it is possible to edit and add bullet points and numbered lists to bulleted or numbered lists that already exist in a Word file. For example, if you copy a Word file from the computer, and that Word file contains some bullet-points, you can add another bullet point by placing the insertion point ("blinking line"😉 at the end (or beginning) of one of the bulleted items, and drawing the "Return" character on the screen (on UIQ devices, the Return character is drawn like a "/"😉. The new line you create will also be bulleted, and will be on the same level (indent) as the line above (or below) it. The same applies to numbered lists - if you draw a Return character at the end of a numbered item, it will create a new numbered item on the next line, on the same level, and each following numbered item of the same level will be re-numbered appropriately.
Basically, adding new bullets or numbered list items works the same way as in Word on a desktop computer, where you would hit "Enter" at the end of a bullet item or numbered item to start a new line/bullet point/numbered item. If you want to change the indent level of the bullet or number, select Increase Indent or Decrease Indent from the Format menu.
