Is it possible to have 2 different operator settings (Orange & Voda) on one N70 and automatically use the correct settings when the the sim card is inserted?
2 operator settings on 1 N70
As far as I am aware you can have as many settings as you like, you can get the settings sent from the Nokia website.
When it comes to automatically choosing when you insert a sim, I dont believe is possible. You will need to change the Access Points each time you insert the other sim.
Hope this helps.
