Symbian Themes needs the help of someone with a Nokia N90
1 replies · 1,103 views · Started 18 January 2006
Hello,
I hope you've heard of Symbian Themes - AAS's partner site containing thousands of free themes for your device.
You might have also noticed it has been offline for a while. It is returning very soon.
When it reopens, it will fully support the N Series devices, but for this to happen I need the help of some Nokia N90 users.
Please can someone therefore set the date of their phone to 01/01/2000, select the default/general profile and then take a screenshot of the idle screen?
Also can someone either:
  • Send the entire contents of the Z:\System\apps folder
  • Send all the .aif files from within each subfolder with Z:\System\apps
The reason I give both bullet points above is that I think the first bullet point would be less time consuming to do (i.e. just zip up the Apps folder) than the 2nd option (individually finding each aif)...
If you have any webspace, please upload the file(s) and send me a PM with the details. Or if you don't, PM me and I can set up some space on symbianthemes.com to temporarily host them.
Thanks a million. Whoever does this will receive an unlimited download pass when it reopens 😊
Cheers
