It used to work when I got the phone but something got corrupted or deleted I supose when I installed/uninstalled software to the phone and now I can't get it to work.
I tried different means to add the links or shortcuts to the GOTO folders, but when I select the GOTO icon in the menu, it simply bring me back to the main menu.
The only way I can think of to fix this would be to reset the phone.
It might be worth trying to delete the config files for Goto (probably in C:system/apps, but not sure what they are or where they are (someone else might help here).
Is likely the config files are bad and hence the GoTo app wont start.
delta313 wrote:It used to work when I got the phone but something got corrupted or deleted I supose when I installed/uninstalled software to the phone and now I can't get it to work.I tried different means to add the links or shortcuts to the GOTO folders, but when I select the GOTO icon in the menu, it simply bring me back to the main menu.
Nokia N90 handle favorites in another way from other symbian phones. You have probably add shortcut with 3rd party application like AppMan. You must delete all files in c:\system\favorites and 'viola' goto works again.
I can't find any application which can create lnk in favorites correct. AppMan lnk files crash pinboard application and FileMan lnk files are ignored.
