No more moving pictograms
0 replies · 944 views · Started 19 January 2006
Did you already notice that when you use the original installed themes that for example when you block the phone the red bar that crosses the keypad moves or if you acces something to OK sign (the tick) will move. When you use an installed theme from you MMC it doesn't move anymore. The red bar is staying already there or the tick isn't moving. Why is that? Isn't there something to fix so the additional themes will not affect the pictograms?
