[FONT="Arial Black"][SIZE="4"][/SIZE][/FONT]I've just found out from my resources that the Version 5 of the 6630 can only be gained through upgrades on Nokia Service Centers and that Nokia haven't really released a phone with a Version 5, you have to upgrade to have it, that's why it have a Nokia 6630 text when you press *#0000# to check it firmware version.
I'm currently using a Version 4.03.38 version, the one before the V5. and I've found out that when you use the Movie creator, and choose a sound for it the icon displayed on its side is a phone which means that its stored on the phone memory, but it should not be coz its located at the memory card, but when you saved a .WAV or .ARM file on ur MMC the icons there would change to Memory card. Do you find out that same bug too??>.
the next Bug is when you set the Log to 30 days... the total days your phone can display is only up to 25 days.. maybe due to memory issues. so that's all and thanks for the help that i got here! ciao'
Nokia6630 Bug!?
does my above problems are really bugs>?... does updating the firmware solves this issue?,,. like the phone log and the movie creator?, :hmpf: :hmpf:
now i know why there is a Nokia 6630 when i check the version number.
