VPN Software for 6680
2 replies · 1,886 views · Started 20 January 2006
:con?
I've downloaded the Nokia VPN client and installed it on my handset, but I can't find any sign of it apart from in the Apps Manager. Does anyone know if the installation has failed, or how I can invoke it to set up a VPN connection when online?
After the installation you should see it in the Settings app.
Anyway, the VPN client is useless, if you also don't have a Nokia Security Service Manager server to configure VPN policies for supported VPN gateways (Nokia's, or CheckPoint VPN-1 and Cisco 3000 Concentrator VPN gateways):
http://europe.nokia.com/nokia/0,0,77172,0.html
I was hoping to hand craft the settings of the client, but it seems not. Do you know of any other VPN clients available?
