Speed camera files "What ones work on N70"?
2 replies · 2,099 views · Started 21 January 2006
Ok Thanks to a few poeple we have Tomtom working on the n70 but it seems we have an isssue with the speed camera database files.
My results are.
Fine with single file versions.
Just when you try and install the more detailed speed zoned ones that show the speed of the camera your approaching they seem to cause my problems.
Who else is finding this?
Thanks.
Try here h**p://thepiratebay.org/search.php?q=tomtom+postcodes
You will need to download BitLord 1st, download the 'handneld' version and use the files within:icon14: 😊
Works spot on on my N70
Same here as you know, single file OK, multi files and it bombs out. As Ive mentioned in the other TomTom thread though, Im now erring towards thinking its not a TomTom issue at all, as it also does exactly the same thing with another mapping app 😞
