Express opinions about nokia n70 and 90
3 replies · 1,293 views · Started 23 January 2006
Wirelessly posted (NokiaN90-1/3.0535.4.3 Series60/2.8 Profile/MIDP-2.0 Configuration/CLDC-1.1)
Hi.I would like to ask yours opinions about these two phones n70 and n90.Has n70 same problems as n90:damaged pop port,system errors,short battery life and unreliable cover?
Ive had an N70 for about 3 weeks having upgraded from a 6230.
Battery life I would say is fine, with normal use Im sure it would last several days although I generally charge every night anyway. This is not necessarily relevent but Ive had it run Tom Tom for well over 2 hours solid with the screen on all the time (a big battery drain) and still be fine for the rest of the day with maybe 15 mins of calls and a few texts etc, after that it would probably be on 4/7 bars by the end of the evening.
Pop port seems fine and is exactly the same as virtually any other Nokia AFAIK?
The phone has ground to a halt once since I have had it but that was whilst playing around with Tom Tom and skipping between other applications that were running in the background so not really "normal" use. A quick reboot bought it all back fine though.
The camera cover is a bit of a pain as in my opinion it needs a catch or a stronger spring so it can't slide open by itself, but its not a big issue.
The big thing I like about the N70 (and any other Symbian) over my old phone is that if it doesnt do something you want it to do, iin a lot of cases you can download a bit of freeware / shareware that will do the job perfectly!
Thanks for your opinions.But what do you think should i change it? Wobbly corp annoys me,if i am using net i hawe to charge my phone twice or even more times a day.If i bought bl-5c with 970 mha,does it suits to n90.
