Re: Multiple SIS files
0 replies · 1 views · Started 23 January 2006
Jeff,
>Our application and its data files total 3.5MB. To enable installation via
>BT file transfer to phones with low memory (Nokia 3650), we have divided
>this up into 4 SIS files. One for the application and three for the data.
>Is this acceptable for signing? The application also needs 1.8MB of heap
>for it to run. We signal an error if there is not that much available. Is
>this acceptable?
This sounds perfectly accetpable, yes. You will need to Symbian Sign your
application in the standard way...but if your 3 data SIS files contain *only*
data ("passive content"😉 and no binaries at all, they can be signed as
content-only SIS file; a process which is cheaper and faster, as no extra
testing is (or can be) done on the contents. You can find details about content
signing at www.symbiansigned.com.
Kind regards,
Phil
