Hi!
I have some queries regarding submission of my application.
1. My application requires a registration code to be entered as soon as
it is started for the first time after installation. The registration is
based on the IMEI number of the device on which it is being
installed. Do I need to mention this in my Readme.txt file? How can I
provide
them with the registration code without
2. Below are the test results of my application when tested with the
LowMem Tool.
Test Counts: 49
Test Failed(%) : 2 // WSERV 10
Mem Leak: 0
Do I need to raise a waiver for this?
When I get this system dialog of WSERV 10 panic and do not respond
to this dialog with the continue button, it starts showing some KERN
EXEC-3 panic system dialogs and the test failed % goes to 18%. Will
it be a problem?
It is written in the LowMem User Guide that all system and
application dialogs must be acknowledged as the test proceeds.
3. What all documents do I need to submit along with the .SIS file if
Symbian signing an application through a Publisher Certifier?
4. I have four more application that I am planning to go for Symbian
signing. Following are the results when tested with LowMem Tool:
When installed on C: drive(Internal memory)
Test Counts: 49
Test Failed(%) : 0
Mem Leak: 2
When installed on D: drive(Memory Card)
Test Counts: 49
Test Failed(%) : 0
Mem Leak: 0
Do I need to worry about the memory leaks that I am getting when
installed on C: drive?
Thanks & Regards,
Lalit Sharma
"Lalit" <[email protected]> wrote in message
news:NsvKESb5FHA.996@extapps30...
> Hi!
> provide
As a courtesy to your customer? Of course. Never let your customers in the
dark on waht your app is doing when it comes to registering. After all, if
they move to a new device, they should reregister.
> LowMem Tool.
> Test Counts: 49
> Mem Leak: 0
No, you need to fix this. a WSERV 10 panic means that you are activating an
active graphics context.
> it be a problem?
Do you know why you are getting this panic? Is your code doing some
rendering in the appui's ConstructL()?
This is documented in the Symbian Signed docs.
> Test Counts: 49
> Test Failed(%) : 0
> Mem Leak: 2
> Test Counts: 49
> Test Failed(%) : 0
> Mem Leak: 0
Possibly, but that is impossible to tell without having your code. You could
be doing things depending on the installed drive.
Sander van der Wal
www.mBrainSoftware.com
Ok, thanks for replying quickly.
"Sander van der Wal" <[email protected]> wrote in message
news:%23IMa2qc5FHA.996@extapps30...
> news:NsvKESb5FHA.996@extapps30...[color=green]
> > Hi!
> > 1. My application requires a registration code to be entered as soon[/color]
as[color=green]
> > provide
> > LowMem Tool.
> > Test Counts: 49
> > Mem Leak: 0
> No, you need to fix this. a WSERV 10 panic means that you are activating[/color]
an
>[color=green]
> > When I get this system dialog of WSERV 10 panic and do not[/color]
respond[color=green]
> > EXEC-3 panic system dialogs and the test failed % goes to 18%.[/color]
Will[color=green]
> > it be a problem?
> > Test Counts: 49
> > Test Failed(%) : 0
> > Mem Leak: 2
> > Test Counts: 49
> > Test Failed(%) : 0
> > Mem Leak: 0
> Possibly, but that is impossible to tell without having your code. You[/color]
could
> Sander van der Wal
