We want to use Startup list management API to autostart an application
for series60 version 3.0. but its not working.
We have a resource file "123456789.rss" (where "123456789" is the UID of
the application) and its contents are
#include <startupitem.rh>
RESOURCE STARTUP_ITEM_INFO ExampleExe
executable_name = "!:\\sys\\bin\\Example.exe";
recovery = EStartupItemExPolicyNone;
And we copy the following files through package file:
"\epoc32\release\gcce\urel\Example.exe"-"!:\sys\bin\Example.exe"
"\epoc32\data\z\private\10003a3f\import\apps\Example_reg.rsc"-"!:\private\10003a3f\import\apps\Example_reg.rsc"
"\epoc32\data\z\resource\apps\Example_loc.Rsc"-"!:\resource\apps\Example_loc.Rsc"
"\epoc32\data\z\resource\apps\Example.Rsc"-"!:\resource\apps\Example.Rsc"
"\epoc32\data\z\private\10003a3f\import\apps\176426778.rsc"-"c:\private\101F875a\import\176426778.rsc"
Could anybody please tell if the above lines are correct? Or is there
anything we are missing?
Do we require any capability for autostarting applicatrion. Our
application is having capability "None".
Thanks, AMK
Your app should be symbian signed to get it work with startuplist mngmt
["Followup-To:" (vastine) asetettu ryhm��n discussion.epoc.c++.]
AMK <[email protected]> kirjoitti 25.11.2005:
> Hi,
> Thanks, AMK
