Hello,
Is there a special procedure to sign a control panel plug-in?
Some of the tests, which are applicable to the standard applications, are
not applicable to the control panel plug-in.
In example the control panel plug-in can't be closed from the task list (it
is not a stand-alone application).
Regards,
Tony
There is a single generic test procedure which is designed for UI framework
apps. The flexibility required for signing other types of code, e.g. control
panel apps, is gained through getting the (not testable) NT exception or,
where the test house is not sure of how to deal with a particular case,
waivers.
Regards
Hamish
"Tony Stoyanov" <[email protected]> wrote in message
news:MMBWm0m8FHA.1040@extapps30...
> Hello,
> (it
> Regards,
> Tony
