Hi
I found out that (on the S60 3rd edition beta SDK)
RApaLsSession::SetAcceptedConfidence() needs the unconditional
WriteDeviceData capability.
To my mind, this is a bit weird as it would mean that it is not possible to
list the contents of a public folder using a recognizer. So I would like
some clarification on this.
Sander van der Wal
www.mBrainSoftware.com
Hi Sander
RApaLsSession::SetAcceptedConfidence sets the system-wide "confidence"
threshold for data recognizers. By altering this value, rogue software could
either cause data-types to be (incorrectly) recognized when they are not
actually supported by the phone, or alternatively, it could prevent
data-types from being recognized when they are actually supported by the
phone.
Thats why it is protected.
> to list the contents of a public folder using a recognizer. So I would
> like some clarification on this.
I don't really understand the problem here. A recogniser is passed some data
and determines its type, with some level of confidence - what has that got
to do with this function call, or the WriteDeviceData capability? If you
have a legitimate use case for WriteDeviceData then you can always request
this through SymbianSigned.
Regards
H
"Sander van der Wal" <[email protected]> wrote in message
news:qS0tdQEGGHA.1040@extapps30...
> Hi
> Sander van der Wal
"Hamish Willee" <[email protected]> wrote in message
news:gC8I3X8GGHA.1636@extapps30...
> Hi Sander
> could either cause data-types to be (incorrectly) recognized when they are
> not actually supported by the phone, or alternatively, it could prevent
> phone.
[color=green]
> data and determines its type, with some level of confidence - what has
> that got to do with this function call, or the WriteDeviceData capability?
> If you have a legitimate use case for WriteDeviceData then you can always
> request this through SymbianSigned.[/color]
My code looks like this:
// connect to the apparc server
User::LeaveIfError(apaLsSession.Connect());
// Adobe Acrobat Reader recognizes PDF file sbased on the first 1000 bytes.
// To be able to recognize the same files, this must be our buffer size.
User::LeaveIfError(apaLsSession.SetMaxDataBufSize(1000));
// recognizers on certain S60 editions are quite broken.
// EPossible is a reconition on the .pdf extension, which works on all S60
editions.
User::LeaveIfError(apaLsSession.SetAcceptedConfidence(CApaDataRecognizerType::EPossible));// read the contents of the current dir User::LeaveIfError(iEnv->FsSession().GetDir(iCurrentDir.FullName(),KEntryAttMaskSupported, ESortByName | EDirsFirst, iDirList));So if I read you correctly, there is no need to set the confidence, providedthe recognizer system works as expected.--Sander van der Walwww.mBrainSoftware.com
Hi Sander
[color=green]
>> provided the recognizer system works as expected.[/color]
1. There is no need to set the confidence in order to list the files in a
directory. The file listing does not run any recognition.
2. Mmmmm
I would try not to use this call to sort out your problem.
Each recogniser returns a level of confidence - I'd argue that if the
confidence in something being a pdf file is only EPossible, then thats
actually how confident the author is that the file is properly recognised.
If you lower the system wide acceptable confidence then you can make your
app more resistant to an inaccurate file being selected, but what about
every other thing in the system that may now pick up files with a lower
level of confidence.
There are two obvious solutions to this
- add a recogniser that you trust to get better recognition on this file
type
- or first use RecognizeData to determine the type - look at aResult to get
the confidence and determine whether this is acceptable for your app. Then
use the file based on that call.
Hope that makes sense.
Cheerio
H
news:HR%23V%23EDHGHA.1964@extapps30...
> news:gC8I3X8GGHA.1636@extapps30...[color=green]
>> Hi Sander
>> are
>> phone.
>[color=darkred]
>> capability?
> bytes.
> editions.
>[/color]
news:KYg4C5IHGHA.3028@extapps30...
> Hi Sander
>[color=green][color=darkred]
> 2. Mmmmm
> type
> get the confidence and determine whether this is acceptable for your app.
> Then use the file based on that call.
> Hope that makes sense.[/color]
I did write the PDF recognizer myself so I know why it was behaving like
that. The problem was that the recognizer framework on older S60 versions
didn't work properly. The recognizer itself had been used for the Psion and
the 9200 communicator and it worked fine.
Setting a lower confidence level did the trick, let's find out/hope it works
on S60 3rd edition so the trick isn't needed.
Sander van der Wal
> Cheerio
> H
> news:HR%23V%23EDHGHA.1964@extapps30...[color=green]
>> news:gC8I3X8GGHA.1636@extapps30...[color=darkred]
>>> Hi Sander
>>> are
>>> phone.
>>>> possible
>>> capability?
>>> always
>> bytes.
>> S60 editions.
>>[/color]
>[/color]
Hi Sander
Sure it works, but it may well break other applications.
Perhaps try another trick i.e.
Unless you believe that this approach is broken also?
Cheers
H
news:rjPSEoMHGHA.1636@extapps30...
> news:KYg4C5IHGHA.3028@extapps30...[color=green]
>> Hi Sander
>>[color=darkred]
>> 2. Mmmmm
>> recognised. If you lower the system wide acceptable confidence then you
>> can make your app more resistant to an inaccurate file being selected,
>> but what about every other thing in the system that may now pick up files
>> with a lower level of confidence.
>> type
> and the 9200 communicator and it worked fine.
> works on S60 3rd edition so the trick isn't needed.
> Sander van der Wal
>> Cheerio
>> H
>> news:HR%23V%23EDHGHA.1964@extapps30...[color=darkred]
>>>> Hi Sander
>>>> are
>>>> the
>>>> phone.
>>>>> possible
>>>> capability?
>>>> always
>>> bytes.
>>> S60 editions.
>>[/color]
>[/color]
news:P7keZwVHGHA.1944@extapps30...
> Hi Sander
Probably. But is the confidence level is so important, why doesn't it's
entry in the SDK docs state you are setting the global confidence level? I
would assume (no news is good news) that you would set the confidence level
for the current apalssession.
> Perhaps try another trick i.e.[color=green]
> Unless you believe that this approach is broken also?[/color]
I would prefer a recognizer system that works as advertised. There were lots
of people at the time having problems with it in Series 60. Using a
confidence level of EProbably was a hack, to have a shippable product that
would make money.
Sander van der Wal
> Cheers
> H
> news:rjPSEoMHGHA.1636@extapps30...[color=green]
>> news:KYg4C5IHGHA.3028@extapps30...[color=darkred]
>>> Hi Sander
>>> a directory. The file listing does not run any recognition.
>>> 2. Mmmmm
>>> files with a lower level of confidence.
>>> type
>>> app. Then use the file based on that call.
>> Sander van der Wal
>>> Cheerio
>>> H
>>>>> Hi Sander
>>>>> are
>>>>> prevent
>>>>> the
>>>>> phone.
>>>>>> possible
>>>>>> would
>>>>> some
>>>>> capability?
>>>>> always
>>>> bytes.
>>>> size.
>>>> S60 editions.
>>[/color]
>[/color]
G'day Sander
Cursed pragmatism. Well, I've given you another option now - so you can "do
the right thing".
- Re developer library not saying you are setting the global confidence
level - its a defect - I've put in a report.
- I don't care to comment on the general stability of the framework, not
having investigated - but EProbably is a valid return value for a recogniser
that can't recognise a MIME type reliably.
Cheerio
H
news:QFXDmTaHGHA.3124@extapps30...
> news:P7keZwVHGHA.1944@extapps30...[color=green]
>> Hi Sander
> level for the current apalssession.
>> Perhaps try another trick i.e.[color=darkred]
> lots of people at the time having problems with it in Series 60. Using a
> would make money.
> Sander van der Wal
>> Cheers
>> H
>> news:rjPSEoMHGHA.1636@extapps30...[color=darkred]
>>>> Hi Sander
>>>> 2. Mmmmm
>>>> file type
>>> versions didn't work properly. The recognizer itself had been used for
>>> the Psion and the 9200 communicator and it worked fine.
>>> Sander van der Wal
>>>> Cheerio
>>>> H
>>>>>> Hi Sander
>>>>>> "confidence"
>>>>>> software
>>>>>> they are
>>>>>> prevent
>>>>>> the
>>>>>> phone.
>>>>>>> possible
>>>>>>> would
>>>>>> some
>>>>>> has
>>>>>> capability?
>>>>>> always
>>>>> bytes.
>>>>> size.
>>>>> S60 editions.
>>[/color]
>[/color]
news:GOjOgILIGHA.2212@extapps30...
> G'day Sander
> "do the right thing".
> recogniser that can't recognise a MIME type reliably.
It works on S60 3rd edition without changing the global confidence level. So
the call will be removed and I can run without capabilities (for the time
being, who knows what the undocumented document handler framework will need
Sander van der Wal
> Cheerio
> H
> news:QFXDmTaHGHA.3124@extapps30...[color=green]
>> news:P7keZwVHGHA.1944@extapps30...[color=darkred]
>>> Hi Sander
>> I would assume (no news is good news) that you would set the confidence
>> that would make money.
>> Sander van der Wal
>>> Cheers
>>> H
>>>>> Hi Sander
>>>>> in a directory. The file listing does not run any recognition.
>>>>> 2. Mmmmm
>>>>> you can make your app more resistant to an inaccurate file being
>>>>> selected, but what about every other thing in the system that may now
>>>>> pick up files with a lower level of confidence.
>>>>> file type
>>>>> to get the confidence and determine whether this is acceptable for
>>>>> your app. Then use the file based on that call.
>>>> like that. The problem was that the recognizer framework on older S60
>>>> Sander van der Wal
>>>>> Cheerio
>>>>> H
>>>>>>> Hi Sander
>>>>>>> "confidence"
>>>>>>> software
>>>>>>> they are
>>>>>>> prevent
>>>>>>> the
>>>>>>> phone.
>>>>>>>> possible
>>>>>>>> would
>>>>>>> some
>>>>>>> has
>>>>>>> capability?
>>>>>>> always
>>>>>> bytes.
>>>>>> size.
>>>>>> all S60 editions.
>>[/color]
>[/color]
news:H5iA8uLIGHA.2712@extapps30...
> news:GOjOgILIGHA.2212@extapps30...[color=green]
>> G'day Sander
> So the call will be removed and I can run without capabilities (for the
> time being, who knows what the undocumented document handler framework
> will need !@#$%^&*()
> Sander van der Wal
>> Cheerio
>> H
>> news:QFXDmTaHGHA.3124@extapps30...[color=darkred]
>>>> Hi Sander
>>> Sander van der Wal
>>>> Cheers
>>>> H
>>>>>> Hi Sander
>>>>>> 2. Mmmmm
>>>>>> thats actually how confident the author is that the file is properly
>>>>>> file type
>>>>> Sander van der Wal
>>>>>> Cheerio
>>>>>> H
>>>>>>>> Hi Sander
>>>>>>>> "confidence"
>>>>>>>> software
>>>>>>>> they are
>>>>>>>> prevent
>>>>>>>> by the
>>>>>>>> phone.
>>>>>>>>> possible
>>>>>>>>> would
>>>>>>>> some
>>>>>>>> has
>>>>>>>> capability?
>>>>>>>> always
>>>>>>> bytes.
>>>>>>> size.
>>>>>>> all S60 editions.
>>[/color]
>[/color]
