I'm considering to get my freeware application Symbian Signed. After reading
the CellMania terms of service when checking the signup process on the
symbiansigned website I'm a little concerned:
1. CellMania reserves the right not to test or, when tested, not to sign
your application, even if all the tests are passed, without the need for
giving you a reason. This clause gives them the perfect excuse not to do
anything for freeware developers. Suppose I want to submit my current
freeware Series 80 application for signing, will they reject me because
signing is not mandatory for this platform yet (i.e. signed and unsigned
application both have the same rights on the system). I'd like to have more
insight in why an application will be accepted or rejected.
2. Supposing CellMania does sign the application, it is signed with their
own ACS Publisher ID. Does this mean that the signed application will have
the name "CellMania" (instead of "Nokia OK" or "Symbian OK"😉 in the
installation dialog?
3. CellMania (or their selected partner) may use your name and email address
to send you information they think might be relevant for you. Sound like my
mailbox will get even more spam after sumbitting my application for testing,
4. (minor point, but still confusing) The CellMania terms and conditions
seem to be a copy of their terms and conditions (with some minor
modifications for freeware signing) for submitting an application to
CellMania's mFinder program. A lot of terms and conditions therefore seem
not be applicable to freeware signing, but it's hard to tell which ones.
Although I applaud the initiative that freeware can be tested for free, I do
have some problems with the current setup:
a. if you accept the terms of service, you also accept the fact that your
application can be rejected without reason (i.e. you cannot protect against
it) and you're getting additional commercial emails without asking for them
b. there's no alternative (except to fork of 500$ per year for your own ACS
Publisher ID and I don't know how many dollars for getting your application
tested). This is not an option for freeware developers, so you're stuck with
either using CellMania or accept that you can only use a very limited set of
APIs.
I'd love to hear some other opinions about this. If you think I'm rambling
and/or speaking gibberish and/or paranoid, please correct me.
Best regards
Arjen Broeze
