Text / Missed calls notifications do not appear anymore
1 replies · 2,754 views · Started 24 January 2006
I've noticed a very strange behaviour on my Sendo X (latest firmware) lately. Before, whenever i received a text or missed a phone call, a notification dialog would appear on the Now! screen to let me know.
Since a few days, and without any apparent reason, this dialog doesn't appear anymore. The Messaging and Call Log plugins on the Now! screen still work OK and display the number of new texts and missed calls received but the notification dialog never appears. Because of that, i often realize that i've received a text or missed a call only hours later. Very annoying. Does anyone have an idea of what to do to get things back to normal?
Cheers
There's always the reformat trick, I'm sure this would cure the problem...
If you want to keep your messages etc. then try doing a backup first, then re-formatting.
If that doesn't fix the problem, delete the panesettings.ini file in C:\System\Apps\Now then remove the battery BEFORE quiting FExplorer (or whatever you're using) - this will force Now! to reset itself when you reboot the phone.;
