PC suite XP
7 replies · 1,834 views · Started 19 November 2002
I am told by nokia PC suite works with xp but they are unwilling to tell me how to configure it as they will not support it.
Has anone manage to configure it on xp yet using bluethooth
thanks
Robbie,
I've tried numerous different configurations to attempt to get PC Suite working. After spending about 30 minutes on total on hold to Club Nokia, they told me that PC Suite isn't compatible with Windows XP. This was quite irritating to here, as apparently some people have been able to get it working. The CSA is spoke to at Nokia said they had some tentative plans to introduce an XP version early next year.
Spikey
I can guarantee that PC suite can run under both XP Pro and XP Home. I used MSI bluetooth to commnicate between XP home and PC suite.
I have it running on my Dell Laptop with an Acer BT500 Bluetooth key.
It took a while and some reinstalling of the drivers (Latest version) but now it's stable as a rock.
On my other machine with an MSI card attached to the mobo the damn pc suite keeps crashing. I can upload pics / midi files however to it's public folder.
Same happens if I use the Acer Bluetooth thingie on my server .. CRASH.
And that's a windows 2000 machine.
I think it's compatible when it wants to ... and only on tuesdays 😃
I never had a problem installing on my laptop xp pro &pc suite .
put cd in & never a drama.
I use IR 😃 😃 😃 😃 😃 😃
All i had to do was insert cd into drive & it worked straight away I have xp pro with sp1 .
I don't know what else is conflicting with pc suite.
