Hello to all
Nokia 6680 is a great phone, lots of features but I want a simple think, in Missed Calls menu (When I press the green button) to view the Mobile number and other info like in contacts
There is a hidden option? or a program to show this simple info(phone number of a missed call)?
Thank you
V 3.04.37
01-06-05
RM-36
The "Log" app shows more details of received & made calls, data usage.
Note that if the caller's number was hidden/withheld, the list will, of course, not show it no matter what. 😉
N/A wrote:The "Log" app shows more details of received & made calls, data usage. Note that if the caller's number was hidden/withheld, the list will, of course, not show it no matter what. 😉
Yes I know "Log" app shows more details , but usually when I have a missed call , only option is "Show" and "Exit", Show button automatically redirect in "Missed Calls" option in phone menu where I see only Name of the person
In order to see his/her number I must enter in contacts and search for that name......and this is verrrrrry annoying :con?
I need to know the number in Missed Calls because I received allot of missed calls and usually I dial the number from my office phone
Thank you
I see. Nothing that can be done about that, unless or until Nokia changes the phone software (firmware).
There is a workaround to see de number of the missed call ( I don�t Know if this is what you are looking for):
in Missed calls - > Options -> Use number -> Edit.
This will show you the number.
