Best way to get all the contacts off my old SE T630 into the N70... bearing in mind i only have 1 sim card...:con?
Cheers
Cheers
Some options:
Copy all the contact details to the SIM card on the T630 first, then put the card in the N70. If the T630 has more contacts that fit on the SIM, do it in batches.
Synchronize with Outlook on a PC (assuming the T630 has support & software for such) & then synchronize again the N70 with Nokia PC Suite.
Similar synch operation, but this time remote/network synch to a service like http://www.mightyphone.com/ (assuming that also the T630 has SyncML support for synchronization).
Send the contacts over Bluetooth (assuming the T630 also supports that).
another question on contacts
how do you cahge the voice commad to dial a number?
